I did a plenum pull and went to start the engine and it cranks but doesn't start. I checked the codes and got a 11, 21, 34. I cleaned and greased the cas sensor which eliminated the 11 and 21 but am still showing the 34 and the engine still won't start. Would it be safe enough to bypass/relocate just to get the engine running?
Can a Code 34 (det. sensor) prevent engine from starting? - SPGZ11:34:47 07/01/08
